Studbaker
Flight distance : 3750853 ft
Norway
I need the dewarped version of the pictures. Each time I start a mission I do have to remember to toggle on the dewarp function. If I pause the project to change batteries, the toggle is off again when I resume the mission. If I oversee this I do have some pictures dewarped, and some not. This is messing up with my pointcloud. I have to go out again to do the whole work over again.
Please DJI - will you make the parameters so that it remembers the last input from the previous mission -and even in the same mission after batterychange ? I have lost a day of work, and others will do the same.
Also when you start a new project it should remember the last used parameters and propose these as standard. Today I have to change 8 parameters each time, and if I get on of them wrong - or forget one - I am in trouble
Also I have seen that if you by accident touch your zoom dial during the mission - it zooms in. For small zooms, you might not notice, and it screws up your orto/point cloud. Please - have the zoom dial locked during the mission.
I have also seen 2 times that when I restart a mission after a battery change, The 7x lens is active instead of the Wide lens. |
