DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please check once again if there are debris or a part is stuck in the gimbal of your DJI Mavic Mini. ( For example, the DJI drone was powered on when it was folded, or the gimbal protector is not removed. ) Please remove the debris or part that is stuck in the gimbal, restart the Drone, and then recalibrate the gimbal. If the issue persists, then please contact our support team via http://www.dji.com/support to open a case and send back the DJI drone to DJI for further diagnosis. Thank you. |
