DJI Gamora
Hi, GG4. Thank you for reaching out. Please try to isolate the issue by following the steps below:
1. Please check if the connections are correct and the cables are firmly connected, cross check the TRS to RCA cable, RC cable adapter, as well as connection on the DJ mixer are all correct. Try different cables if you have a spare. (DJI's recommended cable is Boya BY-K9)
2. Please make sure that the gain on the OSMO ACTION 3 is set to 0db;
3. Please make sure the firmware has been updated to the latest of the OSMO ACTION 3;
4. If after the above settings, the issue still persists, pls provide the firmware version of the camera, the serial number of the camera, the operation video showing the issue, and the footage recorded for further checking. Thank you for your understanding and support. |
