DJI Gamora
Hello, djiuser_FPAe4PKvsgcE. Thank you for reaching out and we're sorry about the inconvenience. Below are some notes and recommended troubleshooting steps to fix the issue:
[Notes]
• Before updating, ensure that the battery level of the device is above 50%.
• Before updating the firmware, be sure to insert a microSD card (corresponding model: Osmo Action/Osmo Pocket 2/Osmo Pocket)
• While updating, do not power off the device or disconnect the USB cable. Otherwise, the update may fail.
• During updating, it is normal that the screen is grayed out and shows a warning stating that the update progress is XX%, and the image transmission view may appear. Do nothing before the update is completed to avoid affecting the normal updating process.
Troubleshooting Steps:
1. Please make sure that the app version is the latest version (for iOS devices, enter the App Store update list to check whether it needs to be updated and for Android devices, enter an app store to check whether it needs to be updated).
2. Confirm that the mobile device network is normal during the firmware update, a microSD card with a capacity greater than 100M is inserted, and the mobile phone is connected to the DJI Pocket 2 via a smartphone adapter.
3. Please disconnect the DJI Pocket 2 from the mobile device and reconnect the device to update the firmware again.
4. Restart the DJI Pocket 2 and launch the DJI Mimo app to update the firmware again;
5. Please update the firmware via a microSD card. After the firmware update is completed, delete the firmware package (bin file) in the microSD card. (I will DM you the link)
Remarks: Updating DJI Pocket 2 using a microSD card:
a. Connect the microSD card to DJI Pocket 2 using a USB-C cable or connect the microSD card to a computer with a card reader. Copy the firmware package to the microSD card root directory.
b. After copying, if a card reader is used for copying, insert the microSD card into the DJI Pocket 2 card slot for automatic firmware updating. After the update has been completed, connect to the computer and delete the firmware package. When the SD card is inserted into the DJI Pocket 2, please connect the DJI Pocket 2 to the computer to delete the firmware package. When the SD card is unplugged from the DJI Pocket 2, please connect the SD card to the computer via card reader and delete the firmware package.
Thank you for your valued support. |
