Labroides
Flight distance : 9991457 ft
bishop-perun Posted at 10-31 01:01
Hi JJB* and Stephen and thank you for your quick replies. Ok, now I have an answer to one of my questions, landing mode is not possible to disable. But in that case what will happen when it goes to landing mode high in the air - will it turn its engines off and drop down and destroy itself due to a crash or will it continue flying slowly down in landing mode all the way down to the ground and land safely?
No it won't.
If you hold the left stick down, it will descend very slowly because the downward sensors are indicating that it is just above the ground.
When landing, your drone doesn't cut the motors and fall.
It descends until it can't descend any further.
That's what would happen in the situation you describe.
But if the fog was thick and high, it could take several minutes to finally get it down |
