DJI Gamora
nmb1970 Posted at 11-1 13:40
I'm using iOS16.0.3. Not iOS11.
App starts fine and I can go into fly mode and even see the live video stream. after a minute or soo the app stalls and freezes. does not give any kind of error and does not respond to any touch on the screen. the only way "out" is to go to home screen, multitask and force quit the app.
Hi, nmb1970. Thank you for the quick response and for providing more details. I apologize for the confusion, DJI Fly Version 1.7.8 is compatible with the iPhone XR and iOS 11.0 and above. Moving on, please try to check the available memory on your phone. Make sure that it has at least 2GB of memory. You may also try restarting your phone. If the issue persists, please provide us with the following information below:
(1) App version, aircraft model and relative firmware version.
(2) The mobile device model and system version - iPhone XR, iOS16.0.3
(3)What is the operation that caused the crash? Please provide an abnormal screen recording. (Please upload the video to Dropbox or Google Drive and provide us the shareable link)
(4) Provide the time when the crash occurred (to locate the log).
(5) Exported crash log.
How to collect the crash log on iOS:
1. Connect the iOS device to a PC with a USB cable.
2. Run iTunes, and ensure the computer has already been authorized to be trusted by the phone. Then click the phone icon and the “Sync” button
3. You can skip the backup step. When the synchronization is finished, find the crash logs through the following file path: C:\Users\[Your_User_Name]\AppData\Roaming\Apple Computer\Logs\CrashReporter\MobileDevice\ [Your_Device_Name]\
Note: Since this folder is a hidden folder, ensure that the “Hidden Items” box is checked.
Using iTools to export crash logs for iOS devices (based on iTools 4):
When using iTools, select “Toolbox” and then “Crash Reports”.
We will wait for your update. Thank you for your cooperation. |
