This version contains important updates. It is recommended to update the remote controller.
If the update fails, restart DJI RC Pro, and use DJI Fly or DJI Assistant 2 (Consumer Drones Series) to retry.
Overview:
Release Date: 2023.09.05
Remote Controller Firmware: v03.02.05.00
DJI Fly App: v1.11.4
What’s New?
Fixed some minor bugs.
Notes:
Overview:
Release Date: 2023.07.21
Remote Controller Firmware: v03.02.04.00
DJI Fly App: v1.10.0
What’s New?
Added Enhanced Display.* After enabled, the display brightness is enhanced to assist in shooting. However, there are differences between the image quality and the display, while the image quality of the photo or video taken by the aircraft is not affected.
* This feature was initially planned to be Outdoor mode.
Notes: This version contains important updates. It is recommended to update the remote controller.
Overview:
Release Date: 2023.05.25
Remote Controller Firmware: v03.02.02.00
What’s New?
Fixed an occasional issue where the compass calibration was unsuccessful
Notes:
Overview:
Release Date: 2023.04.25
Remote Controller Firmware: v03.02.01.00
What’s New?
Added support for DJI Mavic 3 Pro
Notes:
Overview:
Release Date: 2022.11.02
Remote Controller Firmware: v03.01.1100
DJI Fly App: v1.8.0
What’s New?
Added ability to close theprompt by using C1 and C2 button after the Low Battery RTH prompts (Only available on DJI Mavic 3 Classic, DJI Mini 3 Pro, and DJI Mavic 3).
Added support for DJI Mavic 3 Classic.
Notes:
I often do not support the choices that DJI makes, but that does not matter. However, it is outrageous that they completely remove the AUX lamp control and Front LEDS control, without saying anything in advance. I don't need the C1 marking yet and maybe not at all. The AUX lamp is a big plus of the M3 because you can do a lot with it. And the front LEDS that flash with video is just a big drama, no video comes out nice and tight. big negatives for DJI.
I wish they would elaborate on “fix minor bugs”. As a software engineer those log entries could also mean introduced several new bugs. I think this community spends enough time reporting “minor bugs” so we should know what was updated before we send a Mavic up in the air not knowing what was changed.
Anyone else get that ominous but hopeful feeling when you take off the first time after a firmware update? I do! Even after 800+ flights!
dronethemoment Posted at 4-25 07:22
Please add the ability to toggle the OSD information! It is insane to me that this feature was left off of a "Pro" controller, when it is included on previous lesser models. We professionals desperately need this to happen!
After 7/21/23 firmware on the RC Pro, it cannot find my Mavic 3 Pro.
**update** Seems that the RC Pro isn't the issue, the drone isn't connecting to DJI Assistant 2 either. Firmware Update just sits at loading and cannot export logs. Downgraded RC Pro to previous firmware but no change. Was not updating the Mavic at all, only RC Pro when this happened.
Hello there. Sorry for the inconvenience. Are you getting an error message? And is this for a DJI RC Pro? We will wait for your response. Have a great day ahead.
Mobilehomer - As usual. you're correct. There is now a new Icon there labeled "Enhanced Display" which apparently extends the range of the brightness slider. Thanks
In the latest update (7th July 2023), is the "continue with loss of signal" feature still there in video Waypoints, or as it been removed?
Also (DJI forum mods,) what else, if anything as been removed/added?
Hello there. We can't provide relevant information yet about the future plans for the Air 3 or the RC Pro. Rest assured, this request has already been forwarded to our relevant team for evaluation. Keep in touch by visiting https://www.dji.com as it will be announced officially once approved and released. We appreciate your patience and support. Have a great day ahead.
DJI Tony Posted at 9-7 03:45
Hi Tony
I was just wondering why you only answer the last post in this thread and completely disregards the other request/post above...
it did not fix it for me. i still can not use the radar feature to point towards the drone. It just goes all over the place. I can actually "successfully" complete calibration. Im still only using the RC Pro now as the backup on my Mini 3 Pro and using the DJI RC for my Mavic 3 Pro. it is a real disappointment to have a $1000 piece of hardware with a key feature that just doesn't work and they do not even acknowledge the issue.
If this FW contains important updates then WHY does is say it only fixed some minor bugs? Once again DJI developers are not being forthcoming. Be fair to your customers and tell us what is fixed as I'm sure the development team has a list of fixes.
What’s New? Fixed some minor bugs.
DowntownRDB Posted at 12-27 08:06
I also came here to make this point and then saw that you beat me to it. These updates are SO important that they can't name a single one. When I think of DJI I picture a huge corporation with many different teams segmented into niche areas regarding development. Then when I read stuff like this it sounds like a 2 person mom and pop shop who are in over their heads. You can't have an update's release note that's only 3 sentences long and 2 of those are direct contradictions of each other.
Johnnokomis Posted at 12-27 09:01
There has to be some reason that DJI fails to be more forthcoming with what FW changes bring. No wonder there is such a trust issue with DJI.
Mark MarkySF Posted at 9-19 10:05
Try this - do NOT use the compass calibration routine in the controller. Instead, spin the RC Pro several times in all three axis, the same way you calibrate a phone compoass. It works for me.
