DJI Controller Pink power light and 2 middle lights blinking
3333 13 2022-11-2
kiwicolin
Flight distance : 1179885 ft
I was having trouble upgrading the firware on my DJI Remote (with the screen) it wouldn't work.
I held down the Home button and Powered up, now I'm in some kind of a mode and I can't figure out how to restart the controller normally, it always shows pink and the 2 lights flashing on power.
2022-11-2
DJI Gamora
Hi, Kiwicolin. Thank you for reaching out and we sincerely apologize for the inconvenience you're experiencing with the Remote Controller. To further assess the situation, can you please provide the exact model of the remote? Some controllers that have a screen on them are Smart Controller, DJI RC, and DJI RC Pro. Also, please let us know how did you run the update. We will wait for your update. Thank you for your cooperation.
2022-11-2
kiwicolin
It’s the DJI controller. The light gray one.
I have reset to factory settings, but it’s still showing pink power light and I’m unable to bind it to any drones.
2022-11-2
fans8bb9b82f
It the DJI RC
2022-11-2
arriagamarte
Flight distance : 364229 ft
Im having the same issue...
Please help!
2023-1-26
DJI Paladin
Flight distance : 318 ft
kiwicolin Posted at 2022-11-2 16:03
Hi there. Thank you for reaching out and we're sorry for the late response. Can you please confirm if you still experience the said issue? Can you please try to download the DJI Assistant 2 software on the link below and please update/refresh the firmware to see if the issue persists? If you could provide us a short video showing the issue that would be very helpful so we can check. Please keep us posted. Thank you.
2023-3-13
DJI Paladin
arriagamarte Posted at 1-26 07:54
Please help!
Hi there. Sorry for the late response. Can you please confirm what RC are you using? Is it DJI RC or RC Pro? Can you please send us a short video showing the issue? Please keep us posted. Thank you.
2023-3-13
djiuser_UaO7FAtFQYev
I am having the same issue. Also when I am trying to update the remote, it stops at 78% and then fails. It stops at the installing phase. I already did a factory reset.
2023-4-3
djiuser_2fezpvYB5Fhb
Hungary
Same here.  RC controller show pink/purple (looks blue in the photos) steady on the left and two flashing green leds in the middle.  Controller will not pair with the drone.
2023-4-10
Hungary
Having the same problem.  RC won’t pair while showing purple/pink light on right and two flashing middle green lights.  Any updates?
In addition it seems the battery is no longer charging and I cannot update the firmware.
2023-4-10
djiuser_lsEKo70Gflan
Flight distance : 86929 ft
My DJI rc had one white and two green flashing and all I did was turn on the controller and turn it back off when you turn it off do NOT double push the power and hold it down. ONLY PUSH IT ONCE AND HOLD IT DOWN for about ten seconds. The controller will restart to a single red light and green lights will show your battery level again. Hope this helps!
2023-6-7
recot
I had this problem. Push and hold power button for ten seconds when the contoller closed. Then plug usb to PC while holding power button. It worked for me, i hope it would be helpful...
2023-7-14
djiuser_KT0iXjaf0teg
Malaysia
I got the same problem. I dont know how to fix this. I got pink/purple and 2 green light in the middle. So can you help me a soon as posibble please
2023-8-30
DJI Tony
djiuser_KT0iXjaf0teg Posted at 8-30 05:07
Hello there. Sorry about the late response. May we know what model of the remote controller are you having a problem with? It will be better if you can also show us a video. I appreciate your patience.
2023-9-14
