Niknik
Flight distance : 1595640 ft
Greece
DJI Tony Posted at 11-4 09:02
Hi, Bulcsú. Thank you for reaching out and we are sorry for the trouble caused. Please be advised that due to the recent addition of support for the EU C1 Classification on the Mavic 3 Series, the "Auxiliary LED" and "Aircraft Front Arm LEDs" options have been aligned with the mandatory changes under European Drone Regulation. These changes include the following:
1. The Auxiliary LEDs will be turned on or off automatically during use, based on the actual environment.
2. The LEDs at the front arms of the drone will blink by default for the duration of the UAV being powered on.
DJI Tony, I agree with that but there must be a button to turn it on or off and to work with the automatic mode. For example, if the bottom led is on by auto then ok you can't turn it off but when it is off in auto then You can turn it on or of by a button. |
