DJI Paladin
 Super Moderator
Hi there. Thank you for reaching out. For you to use a larger gimbal tilt angle on the DJI Osmo Mobile 6, please try to extend the extension rod to a proper length, and manually adjust the angle of the pan-axis motor and make it parallel to the ground. Also, hold the grip, and if it is in Follow mode, push the joystick up/down. If this not work on your end, please send us a short video showing the issue for us to check. Please keep us posted. Thank you. |
