DJI Paladin
Phil Light Posted at 1-31 14:03
Thanks for this information. Is there a recommended procedure for securing the gimbal for transport? The DJI Storage Cover doesn't appear to touch the gimbal. I discarded the foam packing material when unpacking the aircraft - assuming it was disposable packing material. Was I supposed to retain that?
Thank you for your response. The built-in gimbal lock may become unlocked due to external impact. In this case, power on the aircraft and then power it off to lock again. During transportation, it is also required to mount the gimbal protector as well. Hope this helps. Thank you for your valued support. |
