Server Error when checking for updates. RC and Mini 3.
12Next >
18319 50 2022-11-6
Skrzak
Poland
Hi. I'm constantly getting a server error when checking for updates, whether on home wifi or mobile.
My current firmwares are:
MIni 3: 01.00.0300,
RC: 01.01.0450
it's 6th October 2022.
The message I'm getting when checkin is: Server Error. Wait a moment and try again (Code:0x115000100001).
Also tried with different batteries, I have 7 of those.
2022-11-6
DowntownRDB
Flight distance : 525 ft
I've had that error before.  One time I cleared the browser cache and the error went away.  Another time I had to use a different browser to get in.
2022-11-6
ro_walker
Brazil
2022-11-10
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to connect your DJI RC to the DJI Assistant 2 software that can be downloaded using the link below then please update the firmware to the latest version and then check if the issue persists. If you still experience the issue after you uploaded the latest firmware on your RC, please try to clear the cache of the browser on your DJI RC and check if there are changes. Please keep us posted. Thank you.
https://www.dji.com/downloads/so ... sumer-drones-series
2022-11-12
Peter Russell
DJI Paladin Posted at 11-12 21:35
https://www.dji.com/downloads/softwares/dji-assistant-2-consumer-drones-series
Hello, I am now having the same issue ref Error Code 0x115000100001 appearing when trying to check for firmware updates. I have tried refreshing 01.00.0400 & updating to 01.00.0450 using the DJI Assistant app, however after downloading the app then sticks at 'Transmitting' 0% before notifying a 'failure to download'. I now cannot be sure what the state of my firmware is and cannot risk flying again until it is fixed. Please advise. Many thanks (& seasons greetings) Peter Russell :- russellpeter1000@gmail.com
2022-12-24
Peter Russell
2022-12-24
DJI Paladin
Peter Russell Posted at 12-24 07:16
Hello, Peter. Thank you for reaching out and we're sorry for the trouble that this has caused. Kindly please try to reconnect to your internet connection and try to uninstall and reinstall the DJI Assistant 2 software on your PC and check if the issue persists. Please make sure to use the DJI Assistant 2 consumer version to avoid issues. Please keep us posted. Thank you.
2022-12-26
Peter Russell
DJI Paladin Posted at 12-26 01:05
Hello, and thanks for your prompt response to my request for assistance. I have carried out your suggestion and reloaded the DJI Assistant 2(Consumer Drones Series) app to my MAC.
It has successfully downloaded and installed the latest Aircraft Firmware 01.00.0450 but still gives the 'Server error (Code:01x115000100001)' message when I 'Check for Updates'. Any further help would be much appreciated. Peter Russell
2022-12-27
DJI Paladin
Peter Russell Posted at 12-27 02:58
Thank you for your response. Can you please take a screenshot of the said error message, Peter for us to confirm it with our relevant team? Please keep us posted. Thank you.
2022-12-30
Peter Russell
DJI Paladin Posted at 12-30 03:14
Thanks for the response.
I'm not sure how to send a screenshot via the Forum so see two alternative attempts below :-
Hope this works. Please let me know.
2022-12-31
kevinktwo2
Flight distance : 63917 ft
I am having similar issues
1-2 14:51
DJI Paladin
Peter Russell Posted at 2022-12-31 01:43
Sorry for the late response. We will coordinate this with our relevant team to check. We will keep you posted. Thank you.
1-5 04:28
Peter Russell
DJI Paladin Posted at 1-5 04:28
Hello, do you have any response from the DJI team yet?  Do you think the drone is safe to fly pending a response?
1-16 04:56
DJI Paladin
kevinktwo2 Posted at 1-2 14:51
Hi there. Thank you for reaching out. Kindly please update your aircraft and remote controller via DJI Assistant 2 software and check if the issue persists. Please let us know if you encounter an error message on the software. You may download it using the link below. Please keep us posted. Thank you.
1-19 04:18
DJI Paladin
Peter Russell Posted at 1-16 04:56
I will send you a PM, kindly please check. Thank you.
1-19 04:21
Peter Russell
DJI Paladin Posted at 1-19 04:21
Have sent the log as requested, but the error message seems to have been fixed by the latest RC firmware upgrade to 01.02.0300. I'll let you know of any further problem. Many thanks for your assistance.
1-19 09:13
DJI Paladin
Peter Russell Posted at 1-19 09:13
Great! Thank you for keeping us posted and we are more than happy to know that the issue was already isolated. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
1-20 22:27
djiuser_XbkC7t9Z0lT9
New Zealand
I ran into this error too and discovered that you can do firmware updates via the Profile section in the RC's Fly app. This route got me past the error.
I also needed to login to DJI again in the app, unsure if this made a difference or not as I didn't re-check upgrading via the About menu in the Fly app.
1-25 11:42
mpwobbly
Flight distance : 37208 ft
djiuser_XbkC7t9Z0lT9 Posted at 1-25 11:42
Having the same issue and error code but thanks for the tip about updating via profile - it took a couple of tries but eventually worked. Aircraft and remote updated.
2-10 19:54
djiuser_nNP8C3BrNV3Q
Flight distance : 71207 ft
Thanks, worked a treat
2-11 08:56
djiuser_C4qQpOsDK1ld
Flight distance : 10840 ft
I had the same issues. It would not do updates.  It kept saying the wait and try again sort of thing. Tried from RC DJI fly apps profile, settings, update firmware section and it worked.
3-8 12:13
DJI Tony
djiuser_C4qQpOsDK1ld Posted at 3-8 12:13
Hi there. We're sorry you encountered such issues. We are glad you managed to resolve the issue. For your reference, ensure that you are logged in to your account in the DJI RC and it's connected to a network before you perform a firmware update.
3-11 22:11
Axyl
Flight distance : 4304 ft
Legend, mate. Thank you. This workaround did the job. Cheers for posting it
4-1 07:13
AJ CoRe TV
Flight distance : 19928 ft
In RC Clearing cache (storage settings) & using profile section to “firmware” fixed it for me! Thx
4-2 10:24
bpapes
Croatia
Hi, this is a great tip, after having the same issues with updateing the firmware throught About section you opened my eyes with the possibility to update it through a Profile/Settings.
I successfully made an update that was.
4-7 11:40
Staredsky
I have the same issue. The error is never the same; some time is 0x115000100001m some times 0x115000200001 or  0x115000200003 and so on. Pls note that:
1) i cleared the cache of the DJI RC
2) i tried to update and from the profile and from the gofly section
3) Wifi is working because it successfully downloaded and installed an update Flysafe data
The actual app version is 1.9.4 and Aircraft firmware is  01.00.0450
4-8 08:05
DJI Tony
Staredsky Posted at 4-8 08:05
Hi, Staredsky. Thanks for reaching out, and we're sorry for the inconvenience. Kindly refresh or update the firmware using the DJI Assistant 2 (Consumer Drones Series) and check if the error remains. Kindly keep us updated. Thank you.
4-8 21:18
TigerLaosu
DJI Paladin Posted at 2022-11-12 21:35
I am having the issue when checking for firmware updates on RC, so I downloaded the DJI Assistant as suggested and was able to update firmware (both RC and aircraft) successfully using the DJI Assistant. But when I went back to RC and checked for firmware updates again, it gave the same "server not available" error. I cleared the caches and tried again, the same problem! This is worrisome, as it seems to be a very common problem among users.
4-9 08:59
Toufik94
TigerLaosu Posted at 4-9 08:59
I can confirm this. Haven't been using the drone for a while now and tried to update the firmware of the drone but I'm also keep getting this same error message.
I have succesfully updated the firmware via DJI Assisstant 2 to the version V01.00.0450 But when I try to search for the newest version (V01.00.0500) it doesn't show up in the application. And when I try to update the drone via the RC controller (both in camera view and via the Profile section) it keeps giving me the same error message as you. This didn't happened before.
@DJI, what could have gone wrong? I have also cleared my caches and everything but no success.
4-9 09:48
Toufik94
Im having the exact same issue as you. My error message is the same but the error code variates just like yours. I'm also stuck at V01.00.0450
4-9 09:50
Toufik94
The newest update doesn't even show in my list. Even after repeatedly spamming the refresh button. And the rare time when it does pop up it doesn't want to update (update failed)
Something seriously is wrong.
4-9 09:55
RachelGomez
India
When you encounter a server error when checking for updates, it can be frustrating, but there are a few steps you can take to try and resolve the issue:
Check your internet connection: Ensure that you have a stable internet connection, and try accessing other websites to confirm that your internet is working correctly.
Restart your computer: Restarting your computer can sometimes help to clear any temporary issues that may be causing the server error.
Clear your browser's cache and cookies: Clearing your browser's cache and cookies can sometimes help to resolve server errors. To do this, go to your browser's settings and look for the option to clear cache and cookies.
Disable any antivirus software: Your antivirus software could be blocking the connection to the server, so try disabling it temporarily and check if the error goes away.
Regards,
Rachel Gomez
4-9 22:07
DJI Paladin
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to reinstall the DJI Assistant 2 software on your computer and check if the issue persists? Also, can you please confirm what firmware version did you update through the software? Lastly, did you experience any other issues aside from the "server not available" on the DJI RC and your Aircrat?  Please keep us posted. Thank you.
4-10 02:46
MICHAEL5027110
Estonia
on my DJI MINI 3 PRO RC, firmware 01.00.0450 does not allow checking for updates, it constantly writes "Server error. Please wait and try again code: 0x115000100001. Well, I waited and repeated a week already. Please advise what to do
4-14 18:43
DJI Tony
MICHAEL5027110 Posted at 4-14 18:43
Hi there. Thanks for reaching out, and we're sorry for the inconvenience. Kindly ensure that it is connected to a network. You may try logging out, then back in and try again. You may also try updating the firmware using the DJI Assistant 2 (Consumer Drones Series). If these has been performed already, we recommend you wait for the next update. Our engineers are currently working to resolve it as soon as possible. We appreciate your understanding, and continued support.
4-14 21:31
RamblinMan
DJI Tony Posted at 4-14 21:31
I am having the same issue.  If it's a server error, why is the possibility that it is a server error on the DJI side not raised as a solution?   I have the mini 3 pro with the RC controller.  I've cleared cache.  Logged out of my wifi and back in.  Tried updating from profile.  Just keep getting server error messages.
4-27 07:29
amiller2571
Same here
I've tried updating the RC with DJI Flay App and the Assistant 2 (Consumer Drones Series). All just give server errors
4-28 07:44
djiuser_EFG9lEUe88fy
Same here getting server error...
4-29 04:41
DJI Tony
RamblinMan Posted at 4-27 07:29
Hi, RamblinMan. We're sorry for the inconvenience. Have you tried updating it through the DJI Assistant 2 (Consumer Drones Series)? Please keep us posted.
4-29 04:53
djiuser_YFgpe7CZrazC
Hi.
I am getting the exact same issues as everyone on here with the DJI RC and the Mini 3 Pro.
I have tried every step listed here including clearing cache, signing out and in, and performing a factory reset. I try to update the firmware from both areas, including the profile section but neither work and I still get the same message of server error, wait a moment and try again.
I tried to use the Assistant 2 desktop app, but like another user on here I either get an error trying to get the latest firmware or it fails at 99% every time.
This seems fundamentally wrong that a company like DJI has so many users with the same issue.
Any advice DJI of what to do for me and everyone else on here experiencing the same issue?
4-29 09:54
12Next >
