djiuser_Fr3KlXzkpbRW
Lithuania
Hello,
So i noticed after updating to the newest DJI RC firmware, that one of my batteries shows the wrong charging LED sequence.
No matter what is the actual charge of the battery, the charging indication allways goes 1->2->3->4, as if the battery was completely depleted. THis happens both on the drone and in the charging hub.
It charges fine, stops charging fine, and even when the charger is disconnected, the drone and the battery charging hub both show the correct battery charge, but as soon as i connect the charger, it sotarts showing the charge indication as if the battery is completely depleted. This indication stays the same, until the battery is charged to 100%, then it stops and dispays a full charge.
What should i do?
