primeshooter
Flight distance : 1433114 ft
Shifty007UK Posted at 11-7 04:11
I get what you are saying totally. I just prefer to use an ND and save faffing about with the exposure triangle with the Drone in the air as the lens is too fast in daylight and over exposes in the auto settings, I have found ND's good personally as they save me time on the manual settings, they are perfect for it actually although ND grads are better but I don't have one for this. So when I use an ND and expose for the sky I will get obviously a very dark ground and a more natural sky having removed a lot of bright white from the sky when in broad daylight, but without having to go into manual settings and adjust the EV or shutter speed (yes I prefer a low ISO like most would). This means in post production I can pull the colours back out of the dark ground in the Raw file it works much better for me than just under exposing for the sky a stop without a filter or adjusting the shutter speed and messing about with the shot when the drone is in the air losing valuable time. I do it to save time as the cameras auto setting is way to bright for exposure in daylight, you can see so many pictures people have taken in daylight on auto and they are washed out. Yea of course you can change any of the exposure triangle whilst you are in the air to get the same effect, but I am just saving a little time in the air. But yea the lens is fast and as you know bringing the shutter speed down to 1/1000 on a moving car from above is unlikely to cause any motion blur anyway.
Nice shot (but it feels quite HDR ish because of the exact processing method you have described by hyper lifting shadows and pulling your file about to oblivion). You are honestly, 100% using ND's wrong and your shot discipline could improve a whole lot. Don't take this the wrong way but you can improve a whole lot just by listening to my following advice. It takes less than 5 seconds to get the settings that will highly benefit your processing. You argument is nonsenical about bringing stuff out the darkness, simply shooting a bracket would do the same thing only much better.
RAW mode. Get out of auto mode. ISO 100 always. Yes always. f/1.7 aperture is fixed, so f/1.7. Then you simply set it to rotate the wheel the change shutter, until the histogram looks good. Always remember the principals of ETTR (Exposure to the right) which means you pull everything as far to the right side of the histogram as possible without clipping. If bracketing, you can clip a bit of course). Even better, just have it in 5 EV brackets. Press button. The images are taken. Using NDs is for video in drones.
https://www.stevenrobinsonpictures.com/flight
