Axelz
Flight distance : 3427999 ft
Found too the photos size is fixed to 4:3 ratio, you can't change to 16:9 as you can on the standard mavic 3, but this is the maximum 20 megapixel resolution, so I guess optimal in that respect for what the drone is designed for and you can always crop if needed after. The lack of AEB is a bit annoying though if you need HDR type photos with higher dynamic range, but again if you need for video and more flexibility with photos the mavic 3 is the one to go for as it's designed for that purpose. Hopefully they will introduce AEB in a future firmware update though for the M3E. |
