SilentD1
Denmark
DJI Natalia Posted at 11-14 23:39
Sorry for the misunderstanding caused. I've confirmed with the relevant team that the DJI RS3 Pro doesn't have the feature to supply power for the camera. The camera may act as if it is charging when connected to the RS 3 Pro cause the port has voltage ( This also depends on the power supply logic of the camera). But whether it is charging or not depends on the charging power and service power of the camera. And based on our test, the power consumption in this charging process is almost negligible for the gimbal.
As for the settings you mentioned, I'll forward them to the engineers for further checking. Should you have any further questions, please feel free to let us know.
I also tested this claim, and the camera is definitely being charged by the gimbal, But the lock mode seems irelevant. The quirk is that the cable must be inserted before powering on, and the camera may not be turned on or off after the gimbal is turned on. Doing so will stop the charging.
It also charges the camera when its turned off.
Also you cannot have a focus motor attached to the bottom port at the same time, otherwise it wont charge either. It seems to me that the power which was intended for the focus motor is being given to the camera instead.
Which is fine. I mean dont fix that!. I wish they would allow more power through the usb ports to charge and power anything attached to them. Why not!
