DJI Tony
djiuser_VGtMmsis7Oe3 Posted at 2-19 01:28
Hi, latest firmware for Mavic Mini stopped all three of my Mavic Minis from connecting to their controllers. I take the sd card out of the drones, they will connect but you will no longer be able to use your drone with an SD card. As after it connects if you put in an sd card back in the drone the connection is lost again after a few seconds. No way to downgrade as far as I can work out, have tried with dji assistant, but does not have a previous firmware option to go back too (from v01.00.600). Unless DJI does another firmware to fix this, all mavic mini drones are low resolution practice drones from now on. Hope you were not using your drone for a business like me.
Hi there. Sorry about the trouble. Can you please follow the steps below? Feel free to skip some if was already done.
1. Ensure that the correct app is downloaded which is the DJI Fly app. You can download it here: https://www.dji.com/downloads/djiapp/dji-fly
2. Please check whether the aircraft has a microSD card. If yes, remove the microSD card and try linking again.
3. Please switch the linking method between “Linking with the app” and “Linking with combination buttons”.
Remote controller: Press and hold the Power button on the remote controller for four seconds to prepare to link.
Aircraft: Press and hold the Power button on the aircraft for four seconds to prepare to link.
4. If the issue persists, please check whether the remote controller has been updated to the latest version. Connect the remote controller to the app (connect Wifi or hotspot when using RC with built-in screen). Check whether there is a prompt to update the firmware. If yes, update the firmware to the latest version and try linking again.
5. Please connect the aircraft to the computer, check the aircraft firmware version in the DJI Assistant 2, and try linking after updating and refreshing the aircraft’s firmware to the latest version. Here is where to download the software: https://www.dji.com/downloads/so ... sumer-drones-series
Please keep us posted. Have a great day ahead. |
