Ranta62
Thank you for responses, but I think you need to read my post carefully again.
I specifically say that I used DJI Mimo on my iPhone to sync time. The Mobile phone had already sync'd to the Mobile network in the USA so it was displaying local time and location would be USA.
Therefore there is no reason why once the Pocket 2 is sync'd with the Mobile the Pocket 2 should revert back to UK time.
As regards battery level - the battery was at least above 80%, so no, the time going out of sync was not due to the battery losing charge.
I do not understand why DJI have not incorporated a manual Time and Date setting in this device. I can appreciate that Firmware updates need DJI Mimo , but apart from that I have not used it, unless needing to try and sync date and time. My workflow is not requiring DJI Mimo otherwise as I mainly use my SLR 4K camera - BUT - the Pocket 2 is great for stabilising footage and also for casual use around locations.
As I also explained above, after syncing the Pocket 2 time to USA time, I did two test shots and checked teh file time/Date details which were correct. It was teh following day that it reverted back to UK GMT time.
There is no explanation to this if my phone is still correctly sync'd to USA local time from the Mobile network.
