DJI Gamora
Hi, djiuser_js6zoISO6hVc. Thank you for reaching out. We're sorry for the trouble. Please try other ways of using ActiveTrack to check if the issue will persist. Below are the three ways to use ActiveTrack 5.0:
1. Drag a box on the screen in the camera view in DJI Mimo. A green box around the subject indicates ActiveTrack 5.0 is successfully enabled. Tap the icon on the top corner to stop tracking.
2. Enable Gesture Control OFF , select “Follow and Shoot” in DJI Mimo, and perform a palm or V gesture for one to two seconds when facing the camera. The gimbal will
follow the subject closest to the camera. The detection range between the rear camera and the gesture is 0.5 to 4 m. Note that ActiveTrack 5.0 may consume more power and cause the temperature of the mobile phone to increase. Perform a palm or V gesture to stop recording.
3. Press the trigger once to start or stop ActiveTrack 5.0. The gimbal will follow the subject in the center of the screen by default. When using ActiveTrack 5.0 move the joystick to adjust the camera view.
Please note that ActiveTrack 5.0 are not available in the following scenarios:
a. Gimbal mode is set to FPV or SpinShot.
b. The zoom ratio exceeds 3x
Thank you for your support. |
