fans5b25584c
Flight distance : 24012 ft
I've never used our P1 for cracks, or 11 feet away from the subject, but it has phenomenal resolution
Blurry implies to me either a focus problem or a low shutter speed.
I have had significant problems with focus in the past when flying mapping missions, so that would be my first guess
For mapping missions, there is a focus taken at the first point, and if it's off (as in over water), then the focus for every image in that flight will be off, and the mission wasted. To avoid that problem, we define the mission so that the first image point is over land. Since we fly islands, if the satellite image used to define the mission is old and beach has moved, it's a wasted flight.
It's a silly problem for such a sophisticated system.
You don't mention whether you were flying a pre-defined mapping mission when the images were blurry or whether the manual focus pictures were clear.
I haven't tried lately, but they might now allow either manual focus for mapping missions or more than one focus point.
You might also run through the focus calibration sequence to see if that helps.
