Hi All
So I have literally just received my Osmo Action 3 a few days ago. First time out and got some really jittery footage. Its like every step I take the image shakes making eveything blurred. Every bit of footage is the same You don't notice it on playback on phone or camera, only when I play them back on mac or in final cut
Limit your ISO 100-800 will limit your shutter speed and especially if you are filming in a not so bright environment you'll get jitter. What conditions you were using the camera when you got the jitter?
In lower light you want to go into the image settings from 'sliders' icon and turn off the EIS.
What's annoying you can't really tell you should have done it until editing later.
In Pro mode you won't see it but if you change it in un-pro I think the setting stays the same in pro.
Hi there. Thank you for reaching DJI Forum. We're sorry to read about the issue you experienced. Can you please upload the said footage in Google drive or Youtube and send the link here to us for us to check? Please keep us posted. Thank you.
maybe you where in poor light condition and limit the iso at 800 was wrong. i think your shutter speed (on auto for sure) was 1/30 and was too low for the stabilization to work properly.
Retry again but let the iso higher if you want to limit them try 100-3200 or 100-6400.
I have the same issue on occasion. However, there's no shade. It's under open sky. Granted, it's cloudy, but still. Look at the top towards the sky and tree branches. Full auto mode with RockSteady.
As I ride a bike I can get less jitter, but as i walk I will get more jitter, this is where light is needed and the more light with EIS will help, and low light priority, or a gimbal and turn off Rocksteady DJI does not offer less EIS at all. they do want all of us to experience a better shot wit the maximum settings allowed
I seen this in a lot of OA3 videos on youtube in both good and bad light conditions. I called it first "stuttering" but jittering is probably the right word to describe it.
And I have also seen footage from OA3 compared to OA1 and other brands, and OA3 is the only unit that get this jittering.
On all my tests I did with my unit it was never a problem that I know about, but I always shoot in 60 fps so Rocksteady will manage to work properly (if that's the case that cause it).
