DJI Tony
JerseyJim Posted at 11-14 01:33
Thank you Tony for passing this on for the Air 2S on DJI Fly. Even if keeping the slider, maybe a way of "fine tuning" small changes once the slider is held on a particular value. Yes, as mentioned above, a "+/-" fine-tune option would be much easier as well. Also, the adjusted value is located too close to the low end of the slider. Currently a person's finger obscures the value that he is trying to change (a mm at a time with a wide finger), & see at the same time. Of course this would not be an issue if typing a direct entry value. Thanks again.
You are most welcome, JerseyJim. Thank you for the added suggestion as well. We can understand how this, and the previous feedback, would be very helpful for DJI drone users. We always strive to provide the best user experience. Thank you for your valued support. Happy flying! |
