Kiwifranky
DJI Gamora Posted at 11-14 01:23
Hi, Kiwifranky. Thank you for reaching out and we're sorry for the unpleasant experience. Have you tried using a different microSD card to isolate the issue? Kindly check also and remove if there's debris inside the microSD card slot. If it's still snapping out after checking the slot and trying a different card, I'm afraid that you may consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. In addition, warranty service can be claimed depending on the result of the Damage Assessment. Your kind understanding is appreciated and thank you for your continued support.
Hi,
I removed the propeller, to reach the slot a little bit better. Than I used air duster spray on the slot.
It took the card again after that process. I hope this was the first and last time that happened...
Thanks for your feedback!
