osmonauta
Hungary
Just curious, can you name a scenario where you'd never want the camera to turn off automatically?
Auto turn off means that once the camera is not in use in any way, then it will turn itself off. If you never want the camera to turn off all you have to do is set it to 30 minutes and just simply touch the LCD screen once within that half hour (either front or rear) and the timer will reset and now you have another 30 minutes.
If you cannot touch the LCD screen once in 30 minutes then it means (a) you either forgot about it or (b) you're not near the camera.
If (a) you forgot about it, then clearly you're not using the camera and if you are not using the camera it doesn't need to stay on.
If (b) you not near the camera for 30 minutes then, again, you are not using it, so why would you need to have it on all the time?
This is just my "logic". Which, of course, might not be logical for others.
