JJB*
Flight distance : 12401030 ft
Labroides Posted at 11-21 18:53
It's still hard to tell what you are trying to say, your wording is not clear at all.
But I'll respond assuming you are suggesting the drone didn't hit the water, recover briefly, enter RTH, but fall shortly after because of water damage.
Hi Labroides,
Interesting your reply, bc we do have the same idea what happend.
Only you do not fully understand my writing...
1)how to explain drone was in RTH after crasing into water and flips out for 23 seconds?
2)
IMU inside drone, correct but baro sensor is not a watertight sensor. Minus 411 due to water ingress to the sensor.
3)
OSD.isSwaveatwork did show FALSE before the crash as well, 'normal' behaviour flying low over water in Sport mode, so imo no garbage data at all.Only the 4 records just before the disconnect it was True, reading 0.3 vps height. (and True in other parts of this flight as well)
4) Upward vision sensor error also 2x at start of the flight, if one sensor would give as first an error touching water it would be not the upward sensor but downward or side sensors.
So why only the upper sesnsor to give an error? did DJI forgot the other warnings...
After losing signal 6 seconds for Failsafe RTH, correct. So yo do understand what i wrote.
So we agree i guess:
- disconnected flying low at 0.3 meter with speed 11.5 ms, in fwd&roll motion, but did it took 33 meters to stop from 11.5 to zero speed? if all data is correct, than it is 33 meter.
- drone speed to zero, my guess is that during this rapid braking action drone touches water
- drone managed to get dry feet and hover, wait 6 second, into RTH. (cannot think of another reason drone to be in RTH)
- drone gained height to x meter, (for sure in RTH, cannot think of another reason to gain height)
- errors in drone, thus falling down. indeed low in power draw.
Not sure , at first sight, if the last records on the log = the falling down in the video. Drone pitch roll and roll angles not as in the video. But as we see a leg of the drone, camera was approx 80 degeers offset from normal position, so correct.
Camera offset most likely due to first minor impact with water. (minor bc it survived this impact)
Don`t understand why the last records showing a positive vertical speed, while losing height. Must be the water 'damage' to the system.
You ask me "Can i explain without hitting the water..." well i did already in my previous post 16 (...AT...)
See the chart of this flight for the VPS height data.
Green = sensor measuring, White line = not measuring.
I do lot of testing and imo the TrueFalse value on WaveatWork is correct to use.
So for me no garbage, but respect your opinion.
cheers
JJB
