DJI Thor
Flight distance : 13602 ft
Hi, we are sorry for the issue, check the following steps:
1. Please check if you could control the gimbal by the RC. If the gimbal doesn't move, please try to relink the drone and RC.
2. If the gimbal is not controllable, please try to check if the firmware of the drone and RC has been updated, please try to refresh the firmware by DJI Assistant 2 and refer to the tutorial to relink the drone and RC.
3. If you can control the gimbal, please check the connection between the mobile device and controller. Try to replug or change the connecting cable between the RC and the device. If it is possible, you may try to change a different mobile device.
If the issue persists, you may need to send the drone back for further diagnosis.
Please contact our support at http://www.dji.com/support to start a case.
