DJI Gamora
Hi, FlashNY. Thank you for reaching out. The spot seems to be a glare like what other DJI Pilots mentioned. Here are some recommendations to avoid camera lens glare:
1. Use a lens hood: If bright light is just on the side of the affected area, a lens hood can effectively eliminate the glare. However, the lens hood will not work if the bright light is located solely at the front.
2. Adjust the lens orientation: Find a shooting direction that can eliminate the glare. In many cases, the glare at some points can be eliminated by a slight deviation of the light source direction.
3. Block the light source: Block the light source direction with a hand, cap, or paperboard at a position at the front of the lens. In addition, ensure that the blocking object is high enough, which is equivalent to an extended lens hood.
For aircraft, try the steps below:
1. Use a microfiber cloth (such as a glasses cloth) to wipe the lens (rough wiping may damage the coating film).
2. Adjust the shooting angle, and avoid facing toward strong light sources.
3. Add an ND filter.
Thank you for your understanding and valued support. |
