Bashy
Flight distance : 2273123 ft
djiuser_Fr3KlXzkpbRW Posted at 11-25 06:33
The 0:14 in the video was in normal mode. And let me put it this way:
In the same conditions, but in about 15 degree warmer weather, the gimbal would be dead stable when manouvering the same way i did in the video.
My 3rd paragraph is most likely the issue, FWIW, its not the same conditions, its colder. You're flying in -4C, 15C warmer is a big difference.
Heres a bit more on my take, I think you need to send it into DJI, i have a sneaking suspicion it may have taken a tumble at some point, you shouldn't need to use an ND to reduce any Jello effect cause you shouldn't have Jello at all, hence why i think it took a tumble, perhaps a prop is OOB, this, in turn, has made you resort to ND to reduce the jello effect, this, in turn, has led to the wobble, perhaps the extra weight on the gimbal, it happens throughout your posted video, it ranges from hardly noticeable to really bad, the colder air could be putting extra strain on things thus your issue.
Also, if 0:14 is the main issue then you need to edit your 1st post from shake to say "jumps" or @wobble@ as its not shaking and more a jump, and it will be better understood for other members so as to help with better answers. |
