TimmyBaker
Flight distance : 4762051 ft
South Africa
Have been having shocking experiences with this new firmware update...
Everything from "Satellite Antenna Errors" mid flight that once you land it wont let you take off, except its still linked to 18+ satellites.... To having a "Sensor Error" that forces you to land, then it asked to leave the drone on for 5mins and then only restart it.
Signal will go from all GREEN to nearly dropping signal completely deep in the RED only to flip back to GREEN, all without changing the position of the drone. This is all with the drone being in clear radio line of sight and not even tickling longer ranges, this is within 1000ft-1500ft of the operator.
Then there are silly things also like "insufficient satellite information" to drop a GEO pin down, wont work for a good few mins and then just start working again. Unless you come and land, restart and run the risk of the above two issues....
Lastly, our of the two pilots to use the M300, when we updated to this firmware both our flight records were gone. I synced mine back and my colleague tried the same thing with no luck, and support has not been able to assist him with this either as of yet...
BUT I cannot go without mentioning that the M300 is still not compatible with the C2 link of the M30T or visa versa.... Whats up with all the different C2 links out there, even the new M3's just got different C2's from the rest of the fleet.... surely to be an Enterprise solution one would work on standardisation of the controls???
I think its this constant R&D and having to update several firmwares because of disparate hardwares being used is what is biting DJI hard at the moment.
Just wishing for better from DJI, and willing to help where I can... but usually the support from DJI does not help very much and never acknowledges there are real problems... |
