Sean-bumble-bee
Flight distance : 15997 ft
The position is known as the CSC, the manual describes it use,. No one other than DJI knows precisely what constitutes and emergency, if you browse other DJI drone manuals you will find descriptions of what the associated drones consider to be an emergency though I doubt the description will be of much use to you or anyone else, it's too vague in my opinion and/or the drone would be already falling if some of them had occurred.
The summary of all the following is, that if the response to a CSC position is set to the default, "Emergency only", the drone is highly unlikely to stop its motors whilst the drone is in flight. And that is irrespective of how long the position is held.
With the default setting set and the drone in cine mode (simply because it gives the slowest horizontal and vertical speeds), I have 'descended' a mavic mini from around 100m with the sticks in the CSC position the whole way down. All that happens is that the drone descends in a perfectly controlled helix and even automatically slowed its descent as it approached the ground, when I released the sticks the drone hovered.
If you are feeling brave you can test this by hand holding the drone, starting the motors and then giving the drone throttle to make it try to take off from your hand, make sure you have a good grip of the drone. Once the motors are fighting you, wobble the drone fairly vigorously ( to simulate flight) and, with the CSC response set to emergency only, try the CSC position. I think you will find that the motors continue to fight you. If you hold you hand still, to simulate the drone on the ground, and the motors will stop.
I wouldn't have the drone fight you for long, I do not know how easy it is to cook the Mavic 3's ESC's.
HOWEVER, if you change the CSC response to "Anytime" or whatever name the alternative setting is, I suspect you will/would find that the CSC WILL STOP the motors with the drone in 'mid air' AFTER the CSC has been held for around 1.7 seconds, it is around that time with the Mavic 2 and the first two Minis.
Neither option is ideal but "Anytime" has FAR TOO SHORT a delay period to be safe as the normal setting ...... so "Emergency Only" is the better choice.
And yes flying the drone with the response set to Anytime has cost as least two people their drone. |
