benkly
Flight distance : 1131647 ft
DJI Tony Posted at 2-25 00:51
Hi, Benkly. Sorry about the trouble. If the issue persists, please try the procedures below:
1. Ensure that the aircraft mode is normal, i.e., the GPS signal is strong and the aircraft is in non-ATTI mode.
2. Check whether the device drift or unsteady hovering is within the hovering accuracy range, which is shown below:
Dear Tony,
thanks for your answer and affort to help me. I want to answer some of your points:
1.
It only happens for some seconds to 1 or 2 minutes directly after takeoff. Since I use the MC2 I usually start in normal mode. But yes, maybe I didn't wait until good GPS signal. Normally I takeoff with the goggles beside me to reach a safe place and then put my goggles on. What do you mean with ATTI mode, manual mode?
2.
There was no wind and the drone didn't shift. It hovered fine. Only it goes back and up when pressing the MC2 trigger instead of forward.
3.
As I said. No wind and I fly often from this place. This issue never happened with the same drone or others when flying with the RC2. Only happened with the goggles and the MC2.
4.
Motors rotate fine and the propellers are in best condition. Since this only occurs for around 1 minute and after this fly well, I don't think it's something with the motor or propellers.
5.
Yes, there should be no magnetic interference. It flys without issues with the RC2 on the same spot. I am always starting from the street, no traffic around.
6.
No. It only goes up and backwards if I push the trigger, not the stick. If I don't do anything, then it hovers fine. I wait for some time and eventually it reacts ok again and from then on for the complete flight. It's only happens directly after the start when the drone was off (after batterie change).
I think, it's cause the missing GPS. I am too fast by turning on the drone and takeoff. I will take care to wait until it says that the homepoint was updated and takeoff after that. I will take a look on this.
But anyway, thanks that you and your team take care off your customes by monitoring your forum. This is not normal in ourdays and should be honored! |
