Ford4D
Shikijo Posted at 11-25 12:18
1) Yep problem happen with lenses attached too. (video at the end) There is an IR cut before the sensor who can be changed, for 800€ ah ah.
2) The problem coming before updating for the latest FW, update and refresh doesnt change, it's more like mechanical problem of one ND isn't on his good place.
Did you have the IR cut changed? Like for "ghost-hunting" videos and such? It's possible that if you did, the new IR cut is thicker and mechanically blocking something from moving into place.
Regardless, good luck with getting it replaced! |
