Adaptation fonction "active track"
403 1 2022-11-25
djiuser_ESz3P2P9fQ9m
Hello nous cherchons un coder capable d’adapter la fonction « Active Track » au suivi suivi d’insectes en vol par un drone.
Application embarquée sur drone
1°) Mode veille
Détection d’insecte en vol sur un lieu précis
Identification reconnaissance d’insecte
2°) Suivi de la cible identifié (insecte en vol)
Coordonnées GPS du vol
Retour au point de départ du drone.
Cordialement.
Philippe
2022-11-25
Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
That can't be done. You have to do that from scratch in an app.
The active track is in firmware. That can't be modified. Belive me, I have tried combined virtual stick with active track. I gave it up and ended up with a gps solution instead.
It's possible to do image recognition from the livefeed, you have to use special tricks to keep the latency low, but it's possible.
If you want to find a programmer to do an app, I think you should fly manually and show what kind of usecase you after. From your description it's impossible to say, in French as well :-)
2022-11-27
