Map services update,satellite view improvement ?
2009 32 2022-11-26
djiuser_r6soQO9gzSEu
Flight distance : 872415 ft
Hi.
I see in the announcements from Dji there will soon be a change in the map services.
I hope it will include an improved resolution to the satellite view. As it is now in Canada, the satellite view resolution on the map is worse than useless. I can not even determine roads or houses. Might as well have a child scribble the map with crayons and it would probably look better. Very disappointing a company as obviously technologicaly advanced as DJI would allow this to pass review and put it out on their products. Hopefully it is improved soon.
2022-11-26
DJI Tony
Hi there. Thanks for reaching out, and apologies for any inconvenience caused. To further isolate the issue you are experiencing, may we kindly ask for a screenshot of your map view? Please confirm the current app version of your DJI Fly app as well. We will be waiting for your update. Thank you for your kind understanding and support.
2022-11-26
DJI Tony Posted at 11-26 19:17
Hello Tony , thank you for the reply.
DJI rc fly app v1.8.0. RC controller is connected to wifi.
I have attached two screenshots from the RC controller. One is the map view and the other is the satellite view of the same location.
I have also included a screenshot of the same location using google maps satellite  view on my phone for comparison. A better resolution image on the satellite view could be very helpful in navigating flights over natural undeveloped landscapes using landmarks such as rivers, lakes, meadows, clearcuts etc.
I think you will agree that the resolution provided by the satellite image from the RC controller does not provide enough detail to be usable in any way.
Cheers
2022-11-27
DowntownRDB
Flight distance : 1722 ft
djiuser_r6soQO9gzSEu Posted at 11-27 08:46
Like they say - a picture is worth a thousand words.  DJI really does need to address the map issue.
2022-11-27
Bashy
Flight distance : 2354357 ft
I am sure i have read that DJI is working on this already.
2022-11-27
DJI Tony
Thank you for the prompt update and for sharing the screenshots. Please note that this issue occurred probably because your app version is old. We highly recommend you update your app version, then check whether this issue remains. Thank you for your understanding and support.
2022-11-27
Drone.Hunter
Flight distance : 877123 ft
Kazakhstan
DJI Tony Posted at 11-27 23:30
What problem did you fix if you are using a poor quality map service for your RC remote?
2022-11-28
Dirty Bird
Flight distance : 12270610 ft
DJI should use Google Maps, at least for Android users.  They have good resolution & accuracy.  There used to be a trick you could use to force the Go/Go4 apps to use Google Maps.  Not sure if the same is possible for Fly?
2022-11-28
Drone.Hunter
Kazakhstan
Dirty Bird Posted at 11-28 05:21
It is used on the phone, but not in the RC remote.
2022-11-28
Bashy
Yeah, i think the reason they do not is that it costs them money to use the API, the more users, the more it costs....
I thought at 1st that it might be down to that ban the US made ut then this issue is WW so it has to be money.
2022-11-28
Drone.Hunter
Kazakhstan
Bashy Posted at 11-28 06:23
Google maps are used on the same RC (last FW, DJI Fly 1.8.0) where the restricted zones are indicated. And for the flight, MapTiker is used.
2022-11-28
Hi Tony.
As mentioned in my previous post I am running fly app version 1.8.0 on the DJI RC controller.
Can you please tell me what the latest app version is for the DJI RC controller.
2022-11-28
Corsairoz
Flight distance : 733278 ft
I suspect that the reason for not using Google Maps may be one of caching.
When the DJI Fly app is running on a phone, it is, of course, connected to the internet and can cache the map into its local memory as it is needed.
However with the DJI Remote there is no permanent internet connection so the maps shown can only be what is pre-loaded into the remote from the last time it was connected to the internet.
A low resolution map would mean that a larger area could be cached, and probably is. Google Maps resolution would either require a much larger memory in the remote or a much smaller area to be held. Perhaps in the future this could be a use for the Micro SD card in the Remote....
I suspect the very poor resolution currently is associated with the physical memory capacity (and the cache size...) in the Remote.
C
2022-11-28
Drone.Hunter Posted at 11-28 06:47
Google maps are used on the same RC (last FW, DJI Fly 1.8.0) where the restricted zones are indicated. And for the flight, MapTiker is used.https://youtu.be/4YLnGuVVLKY
Thanks very much for posting the video Drone.Hunter.
I just tried the fly spots and yes it has a high resolution image on the satellite view.
I wonder if it has something to do with the mini 3 not having enough processing power to render a high res image while in flight
2022-11-28
Corsairoz Posted at 11-28 07:08
Hi Corsairoz.
Just saw your post after replying to Drone.Hunter.
I think you are correct and I was thinking along those same lines.
2022-11-28
Dirty Bird
One of the benefits of using Google Maps with the DJI RC is, in Google Maps, you can specify an area to be cached to local storage.  The cached map area(s) automatically update every so often.  If stored on a memory card in the DJI RC, this would allow us to have large areas pre-cached & available while flying.  Personally, I have been enabling WiFi during flight & wirelessly connecting to my phone HotSpot so I have live maps, but using Google Maps definable caching would eliminate the need for this.
BTW, I have noticed no degradation in signal or range having WiFi and/or Bluetooth enabled during flight.  In fact when using controllers that require my phone attached both are always enabled & I often have a Bluetooth conversation going on during my flights.
2022-11-28
Bashy
Dirty Bird Posted at 11-28 07:37
I think the wifi and bluetooth part was added because YouTubers thought that that was the issue with regards to the signal, turns out it was not, yet DJI has left this "disabling" in there, to me its ridiculous as its needed for hot-spotting, it needs to be removed again.
2022-11-28
gnirtS
Flight distance : 5712575 ft
Go4 with the original Mavic range used to use MapBox instead of google.
It was woeful, lacking in any sort of detail and accuracy.
Eventually they moved back to Google.
(and FWIW signal wise on my RC-N1 i have no issue with bluetooth, wireless or 4G on *BUT* if i enable wifi hotspot on the phone the signal goes 100m or so at most.)
2022-11-28
RCCrawlerVenezuela
Flight distance : 268110 ft
Venezuela
This contribution made it clear to me what is happening, I had been looking for a solution all weekend because I thought it was a problem with my DJI RC.
Thanks for this post.
2022-11-28
DJI Tony
Drone.Hunter Posted at 11-28 05:08
What problem did you fix if you are using a poor quality map service for your RC remote?[view_image]
Hi there. Thank you for sharing the view of your maps, and we sincerely apologize for the inconvenience caused. We will have it reported to our engineers for further investigation. And just to verify, in your case, does it occur to both the DJI RC and mobile phones, or only in DJI RC? We appreciate your understanding on this. Keep safe.
2022-11-29
DJI Tony
djiuser_r6soQO9gzSEu Posted at 11-28 06:59
Hi Tony.
Thank you for the confirmation and we're sorry to read that the issue remains. As mentioned in the response to Drone.Hunter's comment, we will have it reported to our corresponding team. Thank you for your continued support.
2022-11-29
RCCrawlerVenezuela
Venezuela
DJI Tony Posted at 11-29 00:44
Hi,
This is only happening in the DJI RC, Android or IOS phones do not have this problem.
2022-11-29
Drone.Hunter
Kazakhstan
The situation is similar in the history of flights. Only on RC remote.
2022-11-29
DJI Tony
RCCrawlerVenezuela Posted at 11-29 02:19
Hi,
Hello, RCCrawlerVenezuela. Thanks for the added information. This will surely help our related team further isolate the concern. Thank you for your continued support.
2022-11-29
DJI Tony
Drone.Hunter Posted at 11-29 06:24
Hi, Drone.Hunter. Thanks for the confirmation. Please note that it has been relayed to the concerned team for further checking. We will post an update as soon as we receive feedback. Thank you, and have a nice day.
2022-11-29
Zoooom
Or Linux GPL problems.
2022-11-29
DJI Tony
Hi there. Thank you for your feedback and efforts. We just received confirmation from our engineers. We do notice the issue that the Maptiler has lower satellite accuracy in some countries. Our relevant team is working on this issue at the moment, which will help improve the service quality better and optimize this issue in future App versions. Please stay tuned for updates on our DJI official website (www.dji.com).  Should you have further concerns, please reach back here at DJI Forum. Thank you, and keep safe.
2022-12-3
MRDroneRookie
DJI Tony Posted at 12-3 22:00
Thanks Tony, looking forward to the update.
2022-12-4
DJI Tony
MRDroneRookie Posted at 12-4 11:15
You are most welcome, MRDroneRookie. We appreciate your understanding and support. Have a nice day!
2022-12-4
djiuser_micSFXdbiG7y
Hi everyone, I am new here to the forums and I apologize if I am stating the obvious or if there is a solution that I have simply overlooked.  I am running the DJI RC with my Mavic 3 Classic (but the issue isn't isolated to a drone model) and the maptiler API produces a horrible (zoomed) satellite layer thus making it impossible to use.  I have read conflicting threads that the issue will be resolved but I am not sure continuing to use Maptiler's API is the solution.  For instance, whether  I use the DJI RC or my laptop, the satellite layer imagery is equally bad.
Here is a link to Devil's Gate in the Noosa National Park using the Maptiler Preview:  https://www.maptiler.com/maps/#style=hybrid&mode=2d&position=17.83/-26.378639/153.117964
A picture:
The image displayed on your screen (zoomed in) is the exact imagery that the DJI RC is showing - this is unacceptable...
Contrast the satellite imagery from Google:https://www.google.com/maps/place/Hell's+Gates/@-26.3784711,153.1167685,546m/data=!3m1!1e3!4m5!3m4!1s0x0:0x92db68dc9ba9510!8m2!3d-26.379067!4d153.1190484
Here is a Google snapshot:
1-11 00:22
LV_Forestry
Flight distance : 4726654 ft
Latvia
The reason why DJI stopped using google maps is maybe because of this:
Platform Pricing & API Costs - Google Maps Platform
Plans & pricing of our mapping platform | MapTiler Cloud
1-11 00:40
GSquared
LV_Forestry Posted at 1-11 00:40
@LV_Forestry - yes I agree that the decision was based upon cost; however, the fact remains that it (Maptiler)  is an unacceptable solution for satellite imagery.  Here is an example over my neighborhood - what is this nonsense about?
I acknowledge that cost drives business decisions but as a customer, some decisions affect consumers differently...  And what is important to some is not to others - Thank you for your insight...
Happy New Year
1-11 00:59
Electriflyer
Flight distance : 45597 ft
And still nothing
7-15 20:16
