CitizenVeen
Heya,
I downloaded the DJI assistent from the webpage, its listed under support software for the DJI mini SE. And it also lists the DJI mini SE as 1 of it's supported products. When I plug in an USB-C cable into the charging port on the drone, and the other side of the cable to my comp it starts charging the battery, but no connection is initiated to the computer. Not in file explorer, and when I open the DJI assistent program, it says no connection is found.
Tried both with drone turned on and turned off.
Is the port on the mini SE charge only, or should I be able to connect it to my comp and download images and such directly from the drone?
Thanks
