Georgero
rcschoeni Posted at 2-13 12:22
Hi, The AVATA is the perfect indoor Drone.
I would like to use these in the Enterprise Segment, but I cannot use the glasses.
Please make the AVATA compatible with the RC Pro. From me also as an enterprise Version at a higher price.
Using the AVATA with RC-Pro will not benefit the ones who want to fly in manual mode. The FPV controller 2 can be modified to be used as an FPV controller. The throttle stick can be released and not be a spring-recenter. This is why only this controller can be used with AVATA.
Now if you want to stream from AVATA to an external monitor or TV like in the picture attached you need the RC-Pro, not the Smart controller. Then you connect the drone ,goggles and the fpv controller 2 and from the goggles connect to the RC-Pro via USB-C to USB-C cable and from the RC-Pro to the tv or monitor via HDMI cable. That is the only way so far to have a clear image to share with your audience. |
