StevoB
Slovakia
Bigplumbs Posted at 12-14 23:24
Why do you keep zooming in that is not what an action camera is about or designed for. People who do this so called fix are rather stupid in my view. It probably voids their warranty and possibly ruins the camera for underwater use
You are stupid enough. You probably haven't taken off the protective glass from OA3 in your life, otherwise you wouldn't have written such nonsense. Guaranteed to fall? By gently turning it to 15°CCW, there is no reason to void the warranty, because technically nothing changes, only the micro movement of the lens from the sensor, and the lens is not removed, the only thing that is allowed is the gluing of the lens in the tube, which is not due to waterproofing, but that someone "wise" calibrated and sealed it so that it would not rotate during transport and assembly in the body and "correct" calibration was guaranteed. According to DJI, it is correct for sharpness at infinity... In some videos, they do a complete dissection to show how it works, but to fine-tune the correct focus, you just need to turn the lens, there is no need to remove any sealing rings. The only protective ring against water is orange just below the protective glass, it is the only thing that separates the intestines from the water. The sealing ring on the lens is more of a protection against dirt and moisture when handling and changing ND filters, CPL....so even if there were no black ones, only orange ones you can safely underwater.
PS: You keep stirring up dust and insulting. Whether you're comfortable with softness at a distance where an action camera is used the most is up to you, but don't make fools of them that they want to have it the way it should be, otherwise I'd buy a landscape camera instead of an action camera. NO action camera in the world is as soft in the foreground as the Osmo Action 3! So why are you playing smart, what is it supposed to be used for. Buy the third and fourth, you know, how can I trust you, be happy and if you can't help the mass of people with an obvious technical problem of the manufacturer, then you better shuffle your feet at home. I assume you know how to use the internet, so there are a lot of people on youtube with the same vague problem, so attacking Marc and co is a ridiculous attempt on your part to continue who from whom. And the only reason I keep responding to your nonsense is so that if anyone reading you is new to it and doesn't know, they won't be misled and fooled by your biased propaganda and make their decision based on the evidence of the SOURCES. Have a nice day.
