Bashy
Flight distance : 2354357 ft
I was quite excited to test the Plus battery today, it started as a mess, 1st i put it in to FCC, then whilst i was still faffing sorting out the RC pairing back to the DJI RC, i thought i would save the battery on the drone and turned it off, i then paired the DJI RC and realised that stupidly i turned off the drone and it reset it back to CE lol, so i had to go through that again. Then i had no right yaw so i had to waste more battery rebooting the DJI RC, thankfully i got yaw back, so i had to start with only 86% battery, off i went, i started at about 30m high and after a short while the signal started to drop, i think it was less then 1km when it 1st dropped, any hoo, it was fluctuating throughout the flight, I also had it in mind to turn back at 65%, i managed just a fraction over 6km signal was 3 bars and i was t about 106m high. It was a really poor signal in my eyes because I;d done this journey in both CE and FCC hitting 5.5km during the summer, i would have expected better things at this time of year. I was a tad premature on the 65% and head home as i got back with 35%. I wasn't sure on the best turn around % but at least i know I can go lower.
Anyhoo, it doesn't stop there, i then tried the standard battery in CE mode and I got the same signal issues, 3.3km was the max and again i had to do it at that at 105m high. As I've said before, its done 5.5km at between 16 and 31m under thick fog too, today it had no chance in doing that, bearing in mind that i am flying in the exact same spot and long the same flight path give or take a few degrees. All there was that was different is that there was about 4 tractors working. I am baffled, other than newer firmware, nothing else has changed, so whats going on DJI, I have lost over 2km range not to mention the close in range was poor too as it started fluctuating from about 300m out.
