djiuser_TjahXgL4osTB
South Korea
EpicTree Posted at 12-1 04:15
Did you take the whole lense out or just open the front lense cover (the big screw on one) and then twist it from there without taking it out. And do you just twist it a bit and then put the camera on the same shot and just eyeball it looking better?
dont think ill try doing any of this tbh but curious just to know for future
There is no need to take out the inner lens.
I just slightly grabbed the lens with a long plier and turned it counterclockwise.
At first, it doesn't work well because of the bonding
If you heat it up with a hair dryer and turn it around,
After that, if you apply a little force, it works well. |
