Jiggyb21
Flight distance : 6732 ft
If you wouldn't mind elaborating, what did you have to do? I used to root all my Android phones and mess around but that was years ago. Was it as simple as enabling developer mode and flashing a different RC firmware or something else? I have an Air 2S that theoretically should work.
I, like you, am being driven mad. DJI comes on these forums and answers, I'm sorry, the dumbest questions and only those questions.
Every time I think I've found a workaround to a problem I come across another. I paid for and tested DroneLink and I have to say it's pretty damn good, even the virtual stick missions when paired with the M3E. I tested the same flight today with the M3E vs the Air2S and the M3E definitely performed better but the image is total garbage compared to the Air2S with its control over the color profile, sharpness, contrast, etc. It's not even close. So the 1" sensor blows the 4/3 sensor out of the water. On what planet does that make sense!? Why even put a 4/3 sensor in the M3E?
Anyway if I could get the Fly App to work with the Air 2S, I would assume it would work with the Mavic 3. I'd probably buy an aircraft only and sell the Air 2S so at least I have one controller. I'm so f-ing mad. |
