Sean-bumble-bee
Flight distance : 15997 ft
Sime Posted at 12-4 11:28
One thing to consider though, is that while in flight, the down draft of these drones keeps those pivot points locked into place so I don’t think this issue will cause a problem in flight. That’s my main concern.
True, the thrust from the propeller should keep it in position but the lack of spring indicates a problem in the pivot. It might be a spring that could have taken a set or it broken spring or it could be something progressive that could lead to the failure of the pivot and detach the arm, do you want to risk your drone on that?
Besides 1) I had something somewhat similar in a crash damaged M2Z, the 'slack' allowed the arm to droop at low power settings and on increased power smack into the underside of the airframe 'stop'. I think the drone also wobbled in certain situations but the drone was only flown for a minute or so in a proving/test flight, it was then dismantled and the damaged component found and replaced.
Besides 2) You have posted a thread stating there is a problem and people have advised you to send the drone in for a warranty repair.
If you do not send the drone in but instead continue to fly it and it subsequently fails and the drone crashes and is damaged, DJI might be able to argue that the failure is due to your actions and not covered under warranty or care refresh etc.
Is it worth the risk? In my opinion, on a new, just released drone, no it is not......but it is not my drone or money, at risk.
