johansenfoto
Flight distance : 1173379 ft
Norway
Ralf G. Posted at 3-9 01:53
So... after months of frustration I found an easy solution for the overheating problem. Basically in the EU there is a law that says that a camera needs to shut off after reaching 38°C. This is a very low temperature and is reached very fast, depending on the environement temperature. It seems like with the last firmware update this rule has been implemented (in EU hardware) and that's the reason why the cam shuts off so fast. But... there is an absolutely easy solution! A crack file!!! This file just needs to be installed on the root directory of the memory card and the cam doesn't shut off anymore!!! I was able to record about two hours at 4K30 with a room temperature of 25°C!!! After the recording the camera wasn't HOT at all but just warm to the touch.
If you want to try it out, here is the link to the crack file: https://www.camforpro.com/blog/w ... n-3-crackconfig.zip
Have fun and let me know if it solved your problem too ;-)
Why does it only says "heat test" in the file? |
