GitGud
Flight distance : 159029 ft
Slovenia
Sean-bumble-bee Posted at 12-6 21:59
Check the USB type A socket on the side of the controller for dirt or damage etc. that might be causing a short and some sort of self protection shut down in the controller. Also check the plug for similar. Try another cable but note it may need to be an OTG cable.
Thanks for the suggestion. I have tried replacing the IO board with a different one, and the result is the same, so the problem is not with a USB connector. I will also try with other cable, but I don't think that is the problem.
Thank you for your time, I would appreciate any other suggestions |
