The Saint
Flight distance : 5902228 ft
Ranger7777 Posted at 8-24 08:13
Yes, agree with everything you say. The reason I asked is if you have a drone and are using an add on module for RID it would continuously transmit in flight providing the RID data. That would also be the case with a drone having built in RID as long as it is powered. Attended an On line FAA webinar last night that talked about RID and they were very clear that the intent of RID is to continuously provide this data to personnel such as FAA, Homeland security, local law enforcement and other government entities. So, disconnecting the phone after takeoff no longer makes that data available. I am not saying this is right or wrong, only what was stated in the webinar.
Saw the same webinar and although it was weak. Learned nothing new, mostly tuned it out because it was a waste of time. However, later if I have some free time, I may go back and watch it just in case they said something new but doubt it. Even though their survey indicated 80%+ audience knew all about RID, they pretended like everyone was new to the subject and basically repeated stuff we already knew.
The broadcast module has limitations and for sure, the battery will die while the drone is flying and drone will stop broadcasting. FAA knows this but is ok with at least getting some data rather than none at all. They hope one day there will no longer be a need to use the module and they will be happy when the day comes in which 90% of eligible drones have standard RID. In the meantime, you can be sure you will be left out of important developments if you use a broadcast module such as flying over people or flying BVLOS. |
