Hello DJI team, I am a drone pilot and FPV drone, I own many DJI items and I am very satisfied with them. I would like to obtain the firmware in BETA version of the dji action 2 to be able to try it out exclusively and make a video of it on my social networks and youtube, thank you in advance. Here is my email: contact@directimage.fr
Recorded using
4K/4:3 60FPS Rock steady off
Exposure-Auto
EV +0.3V
ISO 100-400
WB-5500
Color-Natural
FOV-Wide
No ND Filter
Firmware 1.04.04.20
Stabilized using Gyro Flow V 1.4.2
Exported to H.264/AVC 3840x2160
FOV 0.7
Smoothness 0.030
Rolling shutter off.
Then Output to 2.7k with Premier Pro
Managed to get out again and test with the 7 inch Quad. I did get out before and tested, but ended up with overexposed footage.
In my opinion, this beta testing current version is doing a better job than previous one. Where it has improved on the jittering in the scenes that showed shots that were in the distances. The smoothness on any of my turns or when pitching up or down, also looks good on both versions. However, the current version is still showing the same symptoms as the first version. The more I increase smoothness, the worst it gets when I try to remove the vibes from my 7 inch quad frame when making a fast, hard dive. I know, I start introducing resonance into the frame when clocking speeds above 90 km/h. However, those vibes still look better when not stabilized, as you will see in the posted video. Using the side by side screen format, the video on the left is destabilized vs stabilized on the right. I know you cannot perfectly stabilize every footage out there, but using the latest version of the competitor's equipment and software does do a magnificent job.
The form and size factor/weight of the action 2 would be my preference tho !
Danergo Posted at 2-7 07:36
When transiting from normal-light to low-light, I get crazy artifacts with stabilizing with Gyroflow (I guess due to low shutter speed).
Can you make anything to improve this field? Like limiting the shutterspeed to go below 1/xy (which is needed for the stabilization)?
DJI Susan Posted at 2-7 19:54
The beta firmware has been sent to the requested account above, please connect the DJI Mimo and DJI Action 2 and check for the update. Thank you.
Dear Susan,
Can you please enable the betafirmware for me as well? I have a job to be done and it would be really nice to be able to capture the footage using the Action 2 cam, but the job requires usage of GyroFlow.
You for sure, can expect a review of how the firmware behaved.
Mike Leung Posted at 2-9 22:40
I really suggest DJI to make it public beta ASAP. No need to limit the number of beta testers.
As far as I can see, there have been granted beta-firmware to all the recent requesters. Latest was 2 days ago by DJI Susan, to all the requests above.
So I am still thrustful that she will do the necessary to help those in need of that betafirmware :-)
Thank your for adding me to the beta firmware.
Here is my feedback:
I use my two DJI Action 2 most of the time on my motorbike helmet.
The beta firmware already works perfect for this usecase. I had no issues in post production with GyroFlow 1.4.2 as long as there was enough light.
Footage looks very smooth. This firmware will be a game changer. Thank you DJI!
I experienced the same issue like you in low light conditions. Thanks for sharing the video.
DJI Susan Posted at 2-10 20:23
The beta firmware has been sent to the requested accounts above, please connect the DJI Mimo and DJI Action 2 and check for the update. Thank you
Hello Susan,
Thanks a lot for the quick response, this is very much appreciated!
Hi Johan, please rest assured, the beta firmware has been forwarded to your account. Please connect the app and Action 2 and check for the update.
DJI Susan Posted at 2-10 22:36
Hi, I work with aerial footage, I would like to get beta firmware for gyroscope. I will share the result, I will make many flights a day. thank you very much
