[Closed] Looking for DJI Action 2 Gyro Data Beta Firmware Testers
29076 445 2022-12-9
djiuser_5B7wT8UrvIQp
DJI Susan Posted at 2-10 20:23
The beta firmware has been sent to the requested accounts above, please connect the DJI Mimo and DJI Action 2 and check for the update. Thank you
Salve Susan!! Non só se è riferito a me il. Messaggio che è stato attivato il firmware beta 1.04!? Sto provando ma non mi da nessun aggiornamento firmware la action cam
2023-2-12
Danergo
United Arab Emirates
fans5eb1be25 Posted at 2-10 13:19
I experienced the same issue like you in low light conditions. Thanks for sharing the video.
If we record at 60fps instead of 30 or 25 in low light, the footage looks much sharper because we are helping the EIS by higher FPS = faster shutter speeds = better EIS & darker footage.
Honestly, I wouldn't mind having darker footage (as it's dark when we are creating these shots). But I DO mind storing 2x larger files just because someone was incapable of adding a setting which can limit the shutter speed to limit where EIS needs (=prioritize EIS in low light, a feature of Action3).
2023-2-12
Acci FPV
Timarr Posted at 2-8 14:52
Recorded using
4K/4:3 60FPS Rock steady off
Exposure-Auto
Hi! I have notice some similar scenarios that it may be produced by the gyro sensibility. Try enabling low pass filter on gyroflow to see if it improves.
Here is my sample test:
2023-2-12
Paul_trrg
Flight distance : 10499469 ft
Hello, I share my first tests with the new firmware. https://youtu.be/8e5UrnvZOiI
The next test will be in fpv drone and I share it with you...
PS: sorry for mistakes I'm French
2023-2-12
Lucaslab
Flight distance : 700082 ft
Have been in the FPV business for private customers for a while and bought the Action 2 because it is lighter and also better than my GoPro. Would benefit greatly from the beta firmware. I will of course share the results with and without beta here for development.
Email: schweda.luca@gmx.net
Thanks already
2023-2-12
nathanwyt
Hi DJI Team, could you please give me a beta test firware for gyro test, thank you....email : yitian.wu2014@gmail.com
2023-2-12
DJI Susan
The beta firmware has been sent to the requested accounts above, please connect the DJI Mimo and DJI Action 2 and check for the update. Thank you.
2023-2-12
DJI Susan
djiuser_5B7wT8UrvIQp Posted at 2-12 01:58
Hi there, sorry for the inconvenience, could you please check it now?
2023-2-12
djiuser_gsjMd13K5UG5
Hi there, can you please give me access to the new beta firmware? I'd like to test it on my fpv drone. Thank you!
2023-2-12
DJI Susan Posted at 2-12 20:33
Perfetto è arrivato!! Grazie mille
2023-2-13
Pavoda
Czechia
Horizont lock in Gyroflow has issue. It is not still horizontaly
2023-2-13
JonathanTozer
Flight distance : 327195 ft
Hi, can I be added to action 2 beta (gyroflow)
Please
jonathantozer1972@gmail.com
2023-2-13
Florian_Visuals
Hi DJI Team, could you please give me a beta test firware for gyro test, thank you....email : floflojanin@hotmail.fr
2023-2-13
DJI Susan
2023-2-13
EricFilms
Flight distance : 126703 ft
Hi DJI Team, could you please give me a beta test firmware for gyro test, thank you....email : eric2990@gmail.com
2023-2-13
djiuser_EAk6zPVLfKoM
Philippines
Hello, would like to use the beta firmware.
Please grant me access:
chico.gimenez@outlook.com
2023-2-13
djiuser_RTTybZ8n9DYT
Burkemichael2006@gmail.com THANK YOU!!!!
2023-2-13
bbtab
Flight distance : 249347 ft
Hi I would like to be included in the beta firmware test. My email is tabangcora@hotmail.com
Thanks
2023-2-13
DidkuPL
Poland
latest firmware doesn't work so well with gyroflow. On the sides you can see jello (0:04 on the building on the left). There is no jello in the original video (before stabilization). I've tried different settings but they're all the same. There is no jello in gopro :/
https://www.youtube.com/watch?v=Z_yeJ2Y9hK4&feature=youtu.be
2023-2-13
KerryG
Flight distance : 11736709 ft
First test of Version 01.04.04.20
Raw vs GyroFlow Test
2023-2-13
KerryG
Comparing the Action 2 footage stabilized with GyroFlow vs footage from the Action 3 with RockSteady.
2023-2-13
Timarr
Acci FPV Posted at 2-12 06:23
Hey thxs for replying to my post. I went ahead and enabled the low pass filter. You would not believe on how much filtering I had to add just to get it similar to original. I stopped at 500Hz with no improvement after that. I am thinking this action 2 is limited to being stable enough due to the fact it's gyro requires more damping and or the gyro data just needs to be cooked more.
Anyhow, thanks again for replying. See vid below.
After reviewing several, several more times, I do see some improvement with filtering enabled.
2023-2-13
Mc Mike
Flight distance : 852221 ft
Hallo,
bitte fügen Sie mich zur Beta Version hinzu Danke.
rinderwahn67@googlemail.com
2023-2-13
DJI Susan
2023-2-13
feaza2011gmail.com
Japan
Hi DJI Team, could you please give me a beta test firware for gyro test, thank you....email : feaza2011@gmail.com
2023-2-14
DJI Susan
feaza2011gmail.com Posted at 2-14 02:17
Hi there, the firmware has been sent to you, please check it out.
2023-2-14
Dominik__W
Flight distance : 1112218 ft
Poland
May I have access to the beta firmware? dominik__w@interia.pl
2023-2-14
fans3d48ea6b
Flight distance : 1924134 ft
Thailand
I've read the information, the beta firmware still has a problem affecting some futures in the camera. Now I'm changing my mind Thank you for helping me develop and I will follow up on the best results that work for me.
2023-2-14
nivrix
Thank you for the beta firmware. I was testing 01.04.04.20 and it is working quite good. I noticed two problems:
- I can't get Horizon Leveling to work. Constantly shifted by a changing value. Especially with straight recorded videos you can see the twisting with activated Horizon Leveling very well. If it helps I am happy to share my raw video data.
- Since I installed the beta version, when I access the Mimo app, I can no longer see photos I took with the camera. However, I can see them on the SD card and in the camera preview. They are just missing in the app.
2023-2-14
fans649166ed
Flight distance : 770472 ft
Belgium
nafetsone@gmail.com. Betafirmware please
2023-2-14
djiuser_R14TNZERzM6A
F/S : iPhone 14 pro max,canon,nikon,macbook pro,playstation 5 Watsapp no : +201101491095
2023-2-14
510GoShadow
Flight distance : 827316 ft
Can you please add me to the beta? I have asked support they said engineers would push it to me in 2 days but have not gotten anything please would love to try this firmware out
manrooprai510@gmail.com
2023-2-14
510GoShadow
DJI Susan Posted at 2-14 05:30
Can I please get access to this firmware I contacted support & they said engineers would push it by 2 days but have not gotten anything : manrooprai510@gmail.com
2023-2-14
djiuser_WC2TWu8SbD0o
Indonesia
Hi, I need the Beta Firmware for my DJI action 2, I need to used gyro data for my FPV. My email is bagusindra1686@gmail.com, thanks for kind help
2023-2-15
Mattmatt2235
Flight distance : 271017 ft
hello, please I need the Beta Firmware for DJI action 2, for FPV uses. My dji acccount email is : magasin.polders_0n@icloud.com  , thanks
2023-2-15
djiuser_7UKi35EG8pFR
Ukraine
WILL DJI ADD 10 bit to DJI ACTION 2 like Action 3
2023-2-15
Ukraine
and can you send me please Beta Firmware for DJI action 2  my email - ctfire1986@gmail.com
2023-2-15
KM79PL
Poland
Mee to please   kmyszczyszyn@gmail.com
Thanks!
2023-2-15
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
Hi All, the gyro data firmware has been released:
https://forum.dji.com/forum.php?mod=viewthread&tid=261438
Plz upgrade Action2 via DJI MIMO app.
Sincere thank to you guys for the test of beta firmware and feedback.
2023-2-15
nivrix
Thank you for the update. But with the newest firmware horizon leveling with gyroflow is still not working. Is there a chance of that getting fixed?
2023-2-17
