Maximum Survey surface cover by DJI M300
1983 6 2022-12-9
Nickthepilot
Flight distance : 35906 ft
Good morning
I need to scan a 2000 acres property with our DJI M300 with ou DJI L1 Lidar camera.
I am used to do smaller properties and do lidar oblique flights.
Do you have any feedback about how to do it please?
Thnak you
Nick
2022-12-9
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
It all depends on the relief, the vegetation, the buildings... You will have to give more information if you want a precise answer.
A KML file is ideal.
2022-12-9
patiam
Flight distance : 1156358 ft
lol how long is a piece of string?
2022-12-9
Arnor
Flight distance : 2660509 ft
Belgium
I did 125 acres ( 50 hectares ) in 1.5hours, flying around 4.5m/sec @70m AGL with terrain following so depending on requirements : you can cover more if going faster and higher BUT L1 doesn't "like" it.
2022-12-23
hsd
Saudi Arabia
HELLO EVEYONE, CAN SOMEONE HELP ME TO EXPORT THE DATA ( IMAGES , LOG FILES ETC. ) PROCEDURE METHOD. WE ARE USING SURVEYING & MAPPING PROJECTS.
2023-3-30
Johnnokomis
Flight distance : 14031719 ft
hsd Posted at 3-30 16:25
Hey take it easy buddy I know you're excited but there's no reason to come in here yelling. Turn off your caps lock and lets be civil. Now, you're going to have to be a little more specific with what your question is.  I'm not trying to make fun of your poor English but what you just typed in those two sentences doesn't say much. It looks like you put some words in a blender and left the top off. Taking images off the SD card? What drone are you using? What are you needing log files for?
That last one is really none of my business but I'm just curious.
2023-3-30
djiuser_FQ6tH5cIntFN
You can use WebODM if you are searching for affordability. Drone Deploy is another option. I would recommend using Drone Deploy as a free trial offer since it's easier but everyone uses different software. Some use Pix4D, drone deploy, or WebODM.
2023-4-17
