LWay
Hello,
For anyone who still encounters the error with a brand new DJI RC 2 out of the box.
Update your AVATA to the latest firmware 1.03.00 (DJI Assistant 2 Consumer drone series)
Update your DJI Radio Command 2 to the lastest firmware 2.XX.XX (DJI Assistant 2 Consumer drone series)
The problem is in the 3 lastest Google 2 Firmware for me (of course it's not hardware related) so I downgraded to the version which match the AVATA, so 1.03.000 (you still have 2.7k 120fps)
Now, you need to do 4 calibrations : 2 in N then S then M with this technique (you'll see why)
1. Launch everything (Avata + Google 2 + RC 2)
2. Activate Manual Mode in RC control setting
3. Go back to camera view and be sure to be in N mode
4. Go to Status > Calibrate RC
5. The first calibration is just to get the real center (for the google), so put the stick approximately in the center and launch the calibration
IMPORTANT NOTE: Always calibrate the scroll wheel in last and BE SURE YOUR GIMBAL AXYS ARE ALL 0% before the calibration success screen.
6. Then directly after relaunch the calibration (of course don't touch the stick between calibration or you need to return to step 5.)
7. Calibrate stick then Scrool WHEEL when all your axys are 0%
8. Ok now switch to S mode and calibrate again Gimbal, then 0%, then scroll wheel
9. Ok now switch to M mode and calibrate again Gimbal, then 0%, then scroll wheel
10. The message is gone.
11. If the message still there, just insist in M mode or return to step 5 and be sure sticks are 0% at the end of each calibrations and don't touch it between calibration.
Good luck |
