DJI Tony
Hi there. We just received an update from our engineers. Please note that the image transmission bitrate has no relation with ISO, shooting mode nor video resolution, and bitrate. It is determined according to the wireless signal quality, and the wireless signal quality will be affected by many aspects such as the real-time bandwidth of the image transmission and the strength of environmental interference, etc. To adjust the bitrate, users are advised to select the channel bandwidth (40Mhz, 20Mhz, 10Mhz) under transmission. It will assign you the best quality bitrate by default if you choose it automatically. The highest bitrate is related to the channel bandwidth (40Mhz or automatic, corresponding to the highest bit rate of 50Mbps, 20Mhz bandwidth, the highest bit rate is almost halved, 10Mhz bandwidth, the bit rate is reduced by half again), if the aircraft flies far away or blocks the signal, it will drop. You are also advised to change the testing environment and keep notes on the factors that may affect the image transmission bitrate. Thank you for your understanding and support. |
