problem with the photo rendering
565 12 2015-8-16
rbaronetphotogr
I am using a pnatom 3 pro and recently i got a superior right corner blurry greenish spot on my photos but my videos are great. Anybody has a solution for that problem
2015-8-16
chris
Finland
example might help us to help you
2015-8-16
rbaronetphotogr
Here is a sample, I am not used to forum and Pc i am not sure i know how to post an image
2015-8-16
rbaronetphotogr
ok here is the photo
photo with dark spot on th upper right corner
2015-8-16
BobbyB
rbaronetphotogr Posted at 2015-8-16 22:25
Are you using a filter?
2015-8-16
rbaronetphotogr
chris@chris-hil Posted at 2015-8-16 22:07
Dear Chris I did put an image
2015-8-16
chris
Finland
if it wasn't greenish I would say it's just a bit of vignetting becuase of wide angle lenses, have you tried taking photos in 16.9 mode and see if it goes,  and the fact it's only in one corner us odd, vignetting usually all four corners are affected
2015-8-16
chris
Finland
may be a spot of dirt ?? on lens cover
2015-8-16
rbaronetphotogr
BobbyB Posted at 2015-8-16 23:21
I am not using any filter
2015-8-16
rbaronetphotogr
chris@chris-hil Posted at 2015-8-17 00:06
if it wasn't greenish I would say it's just a bit of vignetting becuase of wide angle lenses, have y ...
I will try in 16.9 mode today and see what it does many thanks
2015-8-16
BobbyB
I'm also seeing quite a bit of distortion in the upper right corner.  Could be a defect in the lens/sensor alignment.  You might try removing the stock UV filter from the camera and see if it changes anything.
2015-8-16
AerialLens
Apparently (?) this is from DJI Raw, and not the jpeg photo.  It is almost definitely vignetting (not a dirt spot), which the RAWS almost always contain a wee bit of, and the adjusted jpeg will normally process this out.  Please check to see if you inadvertently are working with a raw file.
Are ALL your images this way?
The reason I am suggesting this is that P3 raw files tend to contain a good deal of distortion (and white spots, too - which you do not seem to have here), and your photo has a LOT of angle divergence in the top half of the image; I have not experienced any sort of distortion or angle divergence (so far) with P3 jpegs. Would you mind taking a look at how your still picture recording is set up? I'm sure you already know you have three choices: JPEG, RAW, and JPEG+RAW.
If you are setup for and prefer RAW, then some good editing software will allow you to save a "preset" for lens distortion. In fact Lightroom actually has a Phantom 3 preset already.
Otherwise, could be a problem for DJI to address.
2015-8-16
rbaronetphotogr
AerialLens Posted at 2015-8-17 00:33
Apparently (?) this is from DJI Raw, and not the jpeg photo.  It is almost definitely vignetting (no ...
Many thanks
I am using raw, you are right on this, but i did not had this semi opaque spot on the right corner so i thougt it was something else. I will try to use jpeg and raw and look at the files.
Robert
2015-8-17
